S55 rear strut flex pipe failure
Old Sep 16, 2013 | 04:01 PM
paulblake427's Avatar
S55, Toyota Amazon, BMW 328I
Anybody come across rear plastic wheel arch damaging flexible hydraulic pipe ?
I could do with some help/guidence on how to change the damaged flexi pipe.
Old Sep 16, 2013 | 05:29 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
you will have to depressurize they system if the hose does not have a leak in it. Undo the connection and swap the hose.
Old Sep 17, 2013 | 02:38 AM
Thanks Shardul, I know the pipe is leaking, anybody know the procedure to remove the rear right strut so I can remove flexible hose from the strut ? I have seen another thread on how to replace the flex hose from the "fixed" metal tube. Any help/guidence would be appreciated.
Old Sep 17, 2013 | 01:19 PM
shardul's Avatar
remove rear parcel shelf to gain access to the top nut and then bottom portion is pretty self explanatory.
Old Sep 17, 2013 | 01:58 PM
Many thanks, I will try and look at over the weekend. Looks I have found a local company to make up the pipe. Onward and upward
Old Sep 17, 2013 | 02:20 PM
Shardul, just had a look, this car has individual fully adjustable rear seats and rear blind etc. Can't see any fixings for parcel shelf, how do you get at its fixings ?
Old Sep 18, 2013 | 04:09 PM
Shardul, no problem found the little cover that allows access. Will be taking strut out shortly. Paul
