ACG Automotive: 2PC Rotor Special for S55!
Old Sep 26, 2013 | 10:34 PM
James@ACG's Avatar
07 RS4 sold, R53 Cooper S, 2008 Cayman S, 2012 GTR
Giro Disc 2 piece rotors, front and rear (slotted) packaged with or without Porterfield R4-S pads!
Slotted rotors without pads: $1600 Shipped
Slotted rotors with Porterfield pads: $2000 Shipped
Get these while they last, only 2 sets available at this price!
Our 2 piece rotors are a direct replacement for the OE disc. No modifications are necessary. The disc will bolt directly to the car and work with OE calipers perfectly. By upgrading your brakes with lightweight high performance replacements as opposed to a big brake kit, your factory bias is maintained as well as your ABS efficiency. The rear rotors are approx 5-6lbs lighter per rotor then the stock units. 23.5lbs vs. 35.5lbs. This reduction in rotational and unsprung weight allows for quicker acceleration and suspension response.
The central hat section of the disc is made from 6061-T6 aircraft specification aluminum. The disc is made from cast iron to the same specification and material as used by professional racing organizations. It is a curved vane design, developed in racing to act as a centrifugal pump to force cooling air through the disc.
The rotor and hat have a floating mount system, which utilizes 10 high strength alloy steel drive pins, manufactured to our own specifications and cadmium plated for a long lasting corrosion resistance. These pins take the load from braking actions while maintaining the axial and radial float between the hat and disc. In order to keep the rotors from making noise when cold, the pins are mounted with anti-noise spring washers on the rotor side which allow the rotor to grow with heat expansion but eliminate the rattle and noise associated with floating rotors. This float also allows the rotor to self center between the pads.
Once the ACG Brake system is in place, simply replace the cast iron rotor when needed for only $350 per corner.
When used with performance pads and hi-temp fluid, you have what amounts to a truly amazing solution to overheating or warping rotors.
Old Sep 28, 2013 | 02:01 PM
Triman2008's Avatar
S55 AMG
WOW, wish I had the cash for these.......not that I need new brakes, but they would look out-fricken-standing behind my Vossen CV3's.
Old Sep 30, 2013 | 01:36 PM
James@ACG's Avatar
Yes they would!
