Looped rail benefits!
Old Oct 22, 2013 | 09:56 AM
Eric_pcars's Avatar
Mercedes s55 amg
Could someone tell me the purpose of the looped rail modification?
Old Oct 22, 2013 | 02:11 PM
cm60k's Avatar
As i know; the rail looped to Eliminate a possibility starvation in the end of the rail,
Especially in Cylinder #8, during high loud rev...
ZAYED,,
Old Oct 22, 2013 | 05:12 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
all theory no supporting data presented.
I have seen at least 5 cars with TTM lopped fuels rail blow the engines.
Old Oct 24, 2013 | 09:34 AM
merc79's Avatar
s55 AMG
Originally Posted by shardul
all theory no supporting data present.
+1,
Old Nov 19, 2013 | 09:01 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
I was never a fan of the looped rail and most big hp cars just use a split line system, where one large fuel line splits into each rail. The bottleneck on our fuel rail is the very small 90 deg inlet on the drivers side rail. Only 5mm ID and you can not flow much fuel through that hole .
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
