Thoughts on my s600 dyno results
Old Dec 5, 2013 | 01:21 AM
iyad.2010's Avatar
E55 AMG W211
Hi Sup guys
so yesterday i went to dyno my car b4 i sell it to see how much i am putting to the ground
my car is an s600 2003 with 115000 km on it
mods are
1- gutted cat + resonater delete
2- k&n drop in air filter
3- bosch 010 upgraded ic pump
first thing i did was cooling the engine for 15 - 20 min
via a big fan
then put it on dyno mode
run was made on a mainline dynamometer it has 2 readings
dyno jet + mainline
on dyno jet readings i got ( 491 rwhp ) yes 491 is this normal ?
on mainline readings i got ( 416 rwhp )
my car is running a bit rich AFR 10.02
what do you think
i apologize for posting in the amg section but seems more appropriate place than the regular w220 section
Old Dec 5, 2013 | 08:04 AM
chawkins2001's Avatar
2006 E55 AMG
That is definitely stout, what were the TQ numbers?
Old Dec 6, 2013 | 05:01 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Dynojets do/can read about 15% higher than load bearing dynos on average.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Dec 7, 2013 | 07:27 AM
iyad.2010's Avatar
E55 AMG W211
590 NM mainline
Old Dec 28, 2013 | 08:56 AM
Greg Schroeder's Avatar
2007 S65
That sounds good.
If you've ever had the car to the drag strip the trap speed is a good indicator of power. With speed, weight and density altitude you can get some pretty useful data.
Times are pretty useless for figuring out power.
Fuel type is a factor too.
