09 S65
Old Jan 29, 2014 | 06:13 PM
Krazz27's Avatar
09 S 65
09 S65
First post time posting on this forum. I bought my first Mercedes S65 4 months ago. I have the extended warranty and unfortunately i have had to take advantage of it multiple times already. Don't get me wrong I LOVE my car but this is getting a little bit ridiculous it seems like there is always something going wrong. My most recent problem happened yesterday. I got in my car to go to work when 5 minutes later my check engine light comes on and i start to lose power. The car started to idle rough so i turned it off and restarted it. The light is still on but the rough idle has gone away. Now as soon as i get over 4k rpm's i start to lose power again and the rough idle comes back until i restart the vehicle. If i stay under 4k rpm's it as though there is no issue (except the check engine light stays on). Is this a common issue with these cars?
Old Jan 29, 2014 | 09:00 PM
canes85's Avatar
2012 S600
Had a CL65 basically the same car except two doors. Sounds like a spark plug or ignition coil issue. Have you replaced your spark plugs? They should be done every 5 years or 60,000 miles. Most people neglect this service cause it costly. Just be glad u have the warranty & enjoy it!
Old Jan 30, 2014 | 09:44 AM
xabo's Avatar
'20 S63
Had a similar issue recently. Check the numbers on your coil packs.
Had the same feeling as you with the "seems like there is always something going wrong" as I've had to use the warranty several times also. It's the nature of the Beast. I look at it this way……as long as it happens under warranty you're good. Get it taken care of and you should have worry free driving for years to come. These cars need and love to be driven and driven hard at times. Most first owners either let them sit, or baby them.
Old Jan 30, 2014 | 12:09 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
how many miles do you have on the car? the MY 09 will have that update coil pack but those also fail around 35k to 40k miles.
Old Jan 30, 2014 | 06:55 PM
s5benzo's Avatar
W221 2013 S550 Rwd, W221 2010 S550 Rwd
These cars have a few common hiccups with the coil packs , spark plugs , abc pump etc .... Enjoy the beast , if you don't mind me asking what company do you have extended warranty through ?
