secondary air pump delete?
Old Nov 14, 2014 | 09:19 PM
Eric_pcars's Avatar
Mercedes s55 amg
Whats the purpose of the secondary air pump? Can it be removed permanently without the CHECK ENGINE light? Where can I purchase one used from? Checked mine and it works sometimes but most of the times it doesn't.
Old Nov 16, 2014 | 11:22 PM
bnash001's Avatar
2003 S55 AMG, 2006 R500, 2006 BMW 325I
The secondary air pump is a motor that starts up when the car is first started and runs for 60 or so seconds to burn excess fuel off until the cats get warmed up. It is part of the emissions system. It is my understanding that you can turn off the code if you have access to the STAR tool but getting someone to do it might be the harder thing. Hope this helps
Old Nov 18, 2014 | 05:38 PM
jnash's Avatar
2017 S63
yes you can do this in STAR but you need the developer mode which dealers do not ordinarily have access to. When you find a friend with dev mode its in the ECU motor module. When secondary air is turned off, your emissions will always be "ready" .
Old Nov 20, 2014 | 12:35 PM
Eric_pcars's Avatar
Mercedes s55 amg
Star computer
Who has a Star computer local to Montgomery Alabama!
