Strange noise at startup
Thanks!
I spoke with a Mercedes mechanic and he told me to change my oil to Mobil 1 0/40 and see if it helps. I'm in So.Cal. and the temp pretty much stays the same "warm" You might want to check where you are and see what your mechanic recommends depending on climate change. Here they are using the Mobil 1 0/40 in all the Mercedes and BMW's. It's bad when my Mercedes sounds like my diesel truck at start up. It's actually embarrassing!
