S55 Starting Issue
Old Dec 11, 2016 | 07:18 AM
Josh_C's Avatar
S55
S55 Starting Issue
I recently picked up a 2004 S55 and it seems to have an issue starting after its been driven. The car will crank and crank but not start. Sometimes it will fire up after cranking a few times, other times I need to wait like 20 minutes and then it will start. I have replaced the camshaft position and crankshaft position sensors with no luck. I took it to a shop when I first got it to get a pulley changed and they scanned it but found no issues. I do have a check engine light but it is from code p0422, which I figure is from the resonators being deleted. Anybody have any idea where I should start?
Old Dec 11, 2016 | 07:47 AM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
Check your fuel pump connectors and relay.
Old Dec 13, 2016 | 08:09 AM
4runnerAmg's Avatar
2003 Mercedes-Benz S55 AMG
I would say check position sensor again or the fuel pump.
Old Dec 13, 2016 | 03:48 PM
GrepAwk's Avatar
'03 S55 (79K miles)
Try replacing CPS
again.
What at you describe for a symptom is exactly what people say about Crankshaft Position Sensor. "After car is warmed up, it will not start until it has cooled down. "
So my recommendation is to swap it again
