ABC Malfunction
I did some research and everyone that has that message popping up seems to be having some sort of noticeable issue. Everything seems to be working just fine in my car. So I was wondering if anyone has had anything similar with their abc system.
Thank you in advanced!
With the car sitting in cold weather, fluid contaminants can settle where they shouldn't, fluid itself contracts from cold, etc., and the above procedure can clear that up. If the problem persists after that, only then would I be concerned about a serious problem.
Good luck,
maw
I had an intermittent issue, where I would get an ABC malfunction warning, which typically went away after a restart.
Turns out it was a damaged module near the left front shock tower.
Once you begin to see warnings on the ABC system, I am of the opinion that you need to head to the dealer promptly, in order to minimize the risk of much larger problems showing up down the road.
