2005 S55 ABC delete
Old Dec 26, 2017 | 08:19 PM
AlexMercedes's Avatar
S55 AMG
I think I'm going to bite the bullet and order these. I was waiting for someone to have them installed and report on the overall quality before getting it myself, but looks like I'm going to be that person! After I deal with this last misfire issue I'm having, I'll definitely order the Ceika coilovers and see how it goes.
Old Dec 29, 2017 | 04:29 AM
William Sidaros's Avatar
2006 Mercedes s55 AMG , 2007 Mercedes s550, 2004 Mercedes CL500
Originally Posted by g60wall
I haven’t order a set from ceika. I’m not happy with yellow speed. The power steering conversion is plug and play you need the mounting bracket. Most used pumps are sold with the bracket. You need a power steering line from pump to steering rack.
On the driver side under the hood there is a fuse box. You can unplug the can bus for the abc and the error becomes white and can be cleared by hitting R
at a minimum please install a front sway bar!
Thank you so much for that info ! And awesome thread btw extremely helpful !!
I will let you know how the Ceikas are as soon as I install them !
Old Dec 29, 2017 | 04:33 AM
I’m about to order them very soon if you wanna wait, by the time I get them and install should be at least a month from now
Old Dec 30, 2017 | 04:40 AM
S55 AMG
Good to know! What are your spring rates, valving, and other customizable options going to be?
Also, here is another thread by g60wall with a lot of information on the conversion process to help you out on your journey:
https://mbworld.org/forums/s-class-w...ngine-out.html
Let us know how everything goes! Good luck!
Old Jul 25, 2022 | 08:04 AM
paste's Avatar
I noticed that after installing the sway bar in the front, it is hitting the ABC lines in the driver's side wheel well. I believe that this is what is responsible for the clunk sound that comes from that side when I go in and out of driveways. I will either try to remove that line or just leave it.
Old Sep 15, 2024 | 08:35 PM
Sebmel123's Avatar
2003 s600
Coilover conversion
I know this post is very old and I apologize if you have already answered this. I have 2003 MB s600 TT. I did the YSR coilover conversion some years ago also and ended up with similar results as yours...too bouncy at higher speeds and when you hit a dip at those speeds, my back end would bounce so high I felt the car was out of control. I ended up with Strutmasters. While I do not like the ride height, it feels way more in control at higher speeds...at least in a straight line. I don't have sway bars on it yet.
So, I have two questions, did you use a w220 S500 front sway bar for yours and did you ever find a good coilover set/system?
No the ride is harsh. I am tapping out on the yellow speed struts after 6 month and going to try cieka coilovers or the b16 bilstein kit from London based company. Only problem is there is no literature on the bilstein kit so will probably go ceika. Going to up the spring rate to from 14 kg front 10kg rear to 18F 14R with the rally valve set up from cieka. The sway bar retrofit really make an abc delete viable
Old Sep 15, 2024 | 09:12 PM
  #32
paste's Avatar
VVK makes coilovers now for the W220. I wish they were paying me to say this but they aren't but that's what a lot of the guys with SL's are running and they seem to think that they are the best. I have an S55 and the suspension has been such a disappointment for a car that I otherwise like. When I did the conversion, the VVK's where not available so I also went with the YSR. I've never gone outside to see my car laid out on the ground but I am really disappointed with how it handles anything other than perfectly smooth pavement.
My car has over 100k miles so I'm not exactly sure that I want to spend several more thousand dollars to replace what is on there when they do there job, just poorly. I run both front and rear sway bars although it looks like the VVK's do have custom sway bars that should provide better handling than the OEM ones. I'm not going back to ABC because it's just not worth it at this point.
Old Apr 11, 2026 | 12:54 AM
  #33
Dthre3's Avatar
2005 S55
What is the part numbers for the sway bars for the front and rear. I was thinking of getting the ones for the s430 for my s55
Old Apr 12, 2026 | 06:12 AM
  #34
paste's Avatar
Front: A2203232565
Rear: A2203201711
You should just go to the junkyard and pull them off a car though
