2003 s55 pulley size help.
edit: also make sure your intercooler pump is in good shape, otherwise order a Bosch 010 ic pump or you'll heat soak and the supercharger will shut off.
83mm is a great pulley setup if youd like to keep your car mostly stock and avoid upgrading the cooling too much past a pump and split cooling
76mm is what most of our customers end up reverting to, and can give you a 30whp increase over stock.
Try checking out our power packages, they are a great guide to the power progression.
you can find them here
Feel free to PM us if you have any questions. We also have Pulley Tune combos available in the pulleys section
