M113k ALTERNATOR PROBLEMS: HOW TO FIX
1st step UNHOOK BATTERY FOOLS
I first put my hood STRAIGHT UP, ( to do this look at the small buttons on the HINGE itself on the hood.. it pushes in on both sides) then removed the front radiator cover, radiator fan, trim, and clamped the upper passenger side rad hose, then the idler pullies, this is a t50 bit I think. Then took off belts. So after that I pulled apart the hose connecting to the module/relay by the passenger headlight, this drains almost all coolant so be sure to buy some more. I then un did both bolts holding the Alternator on, undid the positive underneath the car along with the connection. Then pulled the Alternator right out. Put new one In reverse steps, added coolant and bled system.
This took me about 1.5 hours to remove everything and about 25 min to put everything back.
Be sure to not strip out any bolts! I reccomend getting new ones and also don't forget to find the torque specs for the idler pulleys! If those come off while driving I can't imagine the damage!!
If you have any questions let me know! I figured I would do a quick write up for somebody looking for generic info in removing/tips and tricks. The trick is to take off hoses and pulley. For 2 days I looked hard for a similar situation and didn't not find anything. Just bits and pieces. So this is my exact situation. If you have any tips or questions just ask!!
nice write up. Which chassis did you do this on?
