Blinking fog lights? Help!
2007 Mercedes Benz S550
Like mine to be customized and different!💯 “Blacked Out”🙌🏻
Just replaced and installed new LED fog lights in my 2007 Mercedes Benz S550. When putting them on, they blink 7-10 Times then just shut off. Also shows fog light errors on the dash. Please help...
What I would do is bench test it to make sure the current draw is the same as the stock bulbs and if not wire a resistor in series to drop the current to what you would see on the stock bulb.
SPONSOR/MBworld Guru
In essence, you needed a canbus enabled LED kit, not just any generic LEDs. Otherwise won't play nice with your SAM.
