2009 S63AMG W221 Remove/install cylinder head cover gasket
Old Jul 21, 2018 | 01:42 PM
sbainb's Avatar
2009 S63 AMG
Exclamation 2009 S63AMG W221 Remove/install cylinder head cover gasket
Old Oct 28, 2018 | 10:45 PM
Zerocarpileup's Avatar
2008 S63
Anyone with any information on this? Specifically the torque specs on the valve cover bolts. To reuse bolts or not?
Old Oct 29, 2018 | 09:45 AM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
I attached the WIS file. The bolts can be re-used since they are not TTY bolts, just follow the torque values & tightening procedure.
Proceed at your own risk
Good luck
File Type: pdf
Old Nov 14, 2018 | 06:56 PM
2008 S63
Tightening procedure noted on number 9
