Removing fan and shroud--2005 S55 AMG
There's very little room in there as you know. How difficult is it to remove the fan and shroud to gain more space? Anyone know of a DIY describing how to remove the fan and shroud?
Thanks!
1 Drain coolant from radiator
2 Remove left air intake pipe to air filter
3 Unscrew bolts from retaining tabs (3) on fan shroud (1)
4 Disconnect electric plug connections for suction fan
5 Detach expansion reservoir coolant line on coolant line thermostat housing to engine radiator
6 Detach coolant line (2) at bottom right on engine radiator
7.1 Remove plate attaching ATF line (At bottom of fan shroud)
8 Remove fan shroud (1) i Pull fan shroud with retaining tabs (4) out of retaining lugs on radiator.
9 Install in the reverse order
10 Check coolant level and cooling system for leaks
