S55: pulley questions
Old Oct 11, 2018 | 06:34 PM
Elcajun's Avatar
S55 amg
I have a 2006 S55 AMG and would like the "best bang for the buck" mod which is DIY. I would like to do the pulley mod but :
1. Can I do one without having to have the ECU tuned?
2. Which size to get without having to retune the ECU?
Thanks in advance.
Old Oct 13, 2018 | 10:04 PM
ta72's Avatar
2006 CLS55
77mm clutched pulley and tune would be ideal. You would need a tune if you want to be safe with fuel. The car will not run right without it and also would be dangerous.
Old Oct 14, 2018 | 05:43 PM
C3Duece's Avatar
2002 C32AMG
77 is too small if you want to avoid an ECU tune.
Larger pulleys are available that don't "require" a tune but you'll be leaving HP on the table w/out one.
Old Oct 14, 2018 | 11:29 PM
JQmile's Avatar
2005 S55 AMG
I was thinking of doing an 83mm then maybe a tune later. I'll let you know how it goes if I do.
Old Oct 15, 2018 | 03:54 AM
Elcajun's Avatar
S55 amg
Please do.
I have no plans to go to the drag strip...but would love to have more just because.
I took a trip to Vegas and back to Orange County and found the S55 to be extremely capable esp. Up the incline!
I still have a few things to look at as the front end felt like it had a slight vibration at higher sustained speed! I just replaced the front tires with new balanced Michelin Super Sport too..
Old Oct 17, 2018 | 11:05 PM
E42AMG???'s Avatar
E420
I ran 74mm pulley with no tune for months.
