FS: 2004 Mercedes-Benz S55 AMG - $7,800
Old Mar 19, 2019 | 02:28 PM
Zombie11's Avatar
s55
PRICE DROP: 2004 Mercedes-Benz S55 AMG - $6,000
PRICE DROP: 2005 Mercedes-Benz S55 AMG - 145,000 Miles. $6,000
Selling my '04 S55 AMG.
Just rolled over 145,000 miles today. Has been my daily driver, but i've replaced it.
Recent maintenance, repairs, upgrades include:
Nov. 21, 2018
  • fuel filter
  • washer reservoir cap
  • washer reservoir grommet
Dec. 4, 2018
  • radiator coolant upper hose
  • coolant hose o-ring
Dec. 8, 2018
  • front ABC valve block rebuild
  • rear ABC valve block rebuild
Dec. 12, 2018
  • windshield washer pump
  • throttle body gasket
  • front ABC accumulator
  • rear ABC accumulator
  • rear pulsation damper
  • ABC flush
  • ABC filter
Dec. 28, 2018
  • 180 degree F 82 degree C Thermostat
  • Gates Supercharger Belt
  • Bosch 010 I/C Pump
Jan. 9, 2019
Feb. 16 2019
  • Transmission connector
  • transmission flush
  • transmission filter
  • secondary air injection pump
Mar. 05, 2019
  • oil cooler gaskets kit
  • oil dipstick tube seal
  • fuel tank cap
Mar. 15, 2019
  • A/C Receiver Drier
  • A/C Refrigerant Liquid Hose
  • A/C Compressor
Brand new Continental ExtremeContact DWS tires with around 1,000 miles on them. Also has UPD Belt wrap kit and new Gates belt.
the majority of these parts were purchased through FCP Euro for the Lifetime Warranty should they ever need to be replaced again.
Motor mounts and A/C system parts are sitting on the bench and are brand new but have not yet been installed. The truck only opens with the key and the A/C system needs installed and charged. Tire Pressure System Not Operational light comes on after about :15 of driving.
UPDATE: extra parts i have that will be included with the car include:
  • the aforementioned motor mounts (unless i get time to install this weekend)
  • new OEM A/C compressor, A/C Liquid line and receiver drier
  • 5L of Petosin ATF 134, trans oil pan gasket, trans filter, trans bolt washer, dipstick tube seal, trans fill pipe cover for next flush.
  • extra trans connector
  • new serpentine belt (to accompany A/C component work)
  • new replacement Gates Supercharger belt
  • extra air suspension accumulator for rear ABC block
  • extra X8R valve block Solenoid rebuild kit (for either ABC valve block)
  • 10L Petosin 11s & 2 OEM ABC filters for next flush
  • • original bolts to reverse the UPD Belt Wrap Kit.
  • • all factory books
  • • 2 keys (inc. valet key)
