Another misfire thread...
From what the MB bulletins say, the starting process can lower the voltage and cause ignition issues because of cranking resulting in similar symptoms.
I did remove the cover from the transformer, and the electric smell was extremely strong. I don't know if this is expected or not, but I can understand why with it being sealed so long and getting hot over the years. Can anyone thing of anything I could be missing besides checking the voltage on the individual coil packs, which I intend on doing?
Thanks for any help!
I have done exactly as you have stated - OEM Mercedes/NGK Iridium Spark Plugs gapped at .7mm, cleared all codes with DAS before start attempt, and each time the same 1-6 issue. The coil has less than 500 miles, and was purchased new at the dealer. Which reminds me - when I purchased it I was told it had a 2 year warranty, now I am hearing 1 year??? Anyway I don't think it is the coil but rather the ECI unit.
I think Clark from v12icpack has really done his homework on the ECI and combined with his experience makes a superior product than the OEM ECI. According to EPC, all ECI modues now are listed as "rebuilt" and there are no new ones available any longer. I think since it is narrowed down to this side and nothing has fixed it so far, the ECI has broken down (or possibly the wiring going from the N/91 to N/92/1. I am going to try an ECI I think as I want to enjoy the car this summer. I will let you know my experience if I order from Clark so others will know what to expect, but I feel good about it.
