Turbo Oil/Coolant line O ring 2006 s600
Old Nov 23, 2019 | 03:50 PM
SunderKraut600's Avatar
2006 S600
Greetings.
My friends S600 had a coolant leak on the driver side turbo oil/coolant line, he replaced gasket and reassembled the unit.
All seemed well for about 10 minutes of running before the engine hissed and popped at the gasket and it dumped all the oil.
He’s determined the issue was the orange o-ring around the coolant line was improperly fitted causing a bad seal.
Can someone please show me the proper way to re assemble these lines. Thanks I’m advanced
Old Nov 25, 2019 | 12:11 PM
TECHNICIAN's Avatar
S 63 Coupe, GLS 63
Take out the engine is the proper way
Old Nov 26, 2019 | 05:44 PM
JohnLane's Avatar
222 S-65
OP you can see what a treat that stuff is to get to.
The sealing surface in the turbo needs to get polished up to have a chance at it not leaking. Not happening with those lines in the way.
Those lines are easy enough to deal with once the engine is out. Do all the O-rings on all the lines. Coolant and oil.
Sounds like fun huh!
Old Jan 7, 2020 | 05:38 AM
turbonos7's Avatar
'05 S430, '05 S600
Originally Posted by SunderKraut600
Greetings.
Did your friend ever figure this out?
