valve cover gasket
maw
Do both. Do all 24 spark plugs. Be gentle prying the coil packs off. Little movement at front half of coil pack.... Little movement at rear half. I've heard many horror stories of coil packs getting broken by 'Elroy' who just shoves his big prybar in the middle for predictable results. Don't be that guy!
One side cover has an extra layer or top cover. (Driver’s side in USA?). I forget which side. You will see it. It has a couple of smaller screws. Those screws are incredibly weak (aluminum?). They will easily shear off if you torque them back on too hard during reassembly. Literally hand tight is too tight.
It is recommended by the factory manual that you use all new valve cover bolts (I didn’t) because of potential reactivity between the bolts and the magnesium cover metals.
It helps to have a long open end box wrench with an angled head to pop the plug wires off the plugs.
I suggest not worrying about cost per plug. The price range for the NGKs is not large.
