Front Brake Calipers
Old Apr 19, 2020 | 11:55 PM
conbobway's Avatar
1987 300 TD
Help me out. Replacing front brake pads on an ‘07 S65. Four caliper bolts removed. Calipers are now loose but cannot pull them off of rotor. Pads are partially retracted and not catching on lip of rotor. Pulling out on calipers feels like pulling back on a spring. Cannot imagine that AMG designed this massive caliper assembly where the interconnecting brake line between the two calipers has to be removed in order to lift calipers off to replace pads. This would require bleeding brake lines after reassembly. What am I missing? Thanks in advance.
