ABS
Old May 6, 2020 | 07:13 AM
dwillia3476's Avatar
2003 S55 AMG
ABS
Can my car sit and idol if my abs pump is dry, so I can keep my battery charged or should I just un hook it, because I believe my accutrator are leaking, and don't have time to fix it.
Old May 7, 2020 | 02:22 AM
2003 S55 AMG
Originally Posted by Plutoe
That would not be a good idea,get a second job and fix the pump.
I do work a second job, but I first need to find out why my abs is empty but wanted to know if its to let the car run just to keep the battery juiced, thanks,
Old May 7, 2020 | 06:33 AM
DRTYLNDY's Avatar
If you let the ABC pump run dry you most likely have killed it.
Old May 7, 2020 | 03:52 PM
wfooshee's Avatar
2007 Jaguar XJ8L, 1999 Miata, 2003 Yamaha FJR1300
That was my question... ABS or ABC? ABS doesn't have a reservoir, it's part of the braking system. ABC pump will NOT survive being run while dry.
Old May 9, 2020 | 03:48 AM
2003 S55 AMG
[QUOTE=wfooshee;8049767]That was my question... ABS or ABC? ABS doesn't have a reservoir, it's part of the braking system. ABC pump will NOT survive being run dry thanks will keep that in mind,
Old May 30, 2020 | 06:59 PM
2003 S55 AMG
The fluid for my ABC and the fluid for my power steering are full, but yet my ABC dash light is red on start up, does that mean I need a flush , I have no sag no leaks, if so how did you make your kit?
