Not one of my smartest moments
Do you have a spare 12V battery and jumper cables in your garage you can use to jump start or charge the MB?
I’m just guessing but maybe you could jack up the car and put it on jack stands (to be safe). Then get underneath and remove the plastic front belly pan. Then find the Vbatt 12V feed to the starter motor and hook the spare battery to it and to chassis ground. If that cable leads directly back to the big battery, you could charge it.
Full disclosure: I’m not familiar with the two-battery cars. I don’t know if what I said will work. I don’t know if the 12V feed on the starter is always live, and goes directly back to the big battery in the trunk. And even if it does, whether the security module and door locks are powered off that or the auxiliary accessories battery. Or if the aux accessories battery will charge off the trunk battery when at a healthy voltage over 12V.
But that’s all I can think of. I assume you don’t want AAA to send a tech over to “break in to the car”. Maybe somebody else has an idea.
There might be a sneaky way to pop the trunk but I would rather not contribute to the knowledge of car thieves.
If it’s parked at a convenient place with lots of space in front or behind, most flat bed truck drivers can winch it up onto their trucks with dollies under the rear wheels. Then take it to the dealer to figure it out.
However, That’s pretty dangerous. The car can roll with you under it. Plus, I’m not even sure if such a lever on the transmission is even there or accessible
If you don’t die from that, then you have to figure out how to release the emergency parking brake so that it will roll.
This is all making me think you should just call a good tow truck driver who is familiar with getting nice cars onto the flatbed using dollies and winch and without damaging anything and getting it to the dealership.
