02 S55 AMG - M113K Swap
Old Sep 26, 2021 | 01:55 AM
F87Blake's Avatar
W220 S55
Angry 02 S55 AMG - M113K Swap
Good day. I have been struggling with this issue for about 4 weeks now. I recently swapped my 02' S55 and put a M113K inside of it. I got everything hooked up and it will not start no matter what I do. Here is some vaulable information:
* All interior lights & exterior work & cluster lights up and works
* Fuel pump works when turning to ON
* When I turn the car to start the starter makes no noises. All the wires are connected and working. The START SIGNAL WIRE (Violet wire) is not getting any power. I put two starters in and know the starter isn't bad.
* I sent my TCU, ME, & Ignition switch to a shop to get coded for it.
* The car is getting Drive Authorization.
* No CEL
* Shifter is in park
Feel free to ask any questions. I'm at a crossroads and can no longer figure this out. I'm losing my MIND!
Old Oct 1, 2021 | 12:12 AM
F87Blake's Avatar
W220 S55
Bump
Old Oct 2, 2021 | 12:21 AM
jrbnittany's Avatar
TBD
I've never done a swap, so probably of limited help, but wondering if you also swapped a 55k ECU? I'm not sure, but having the 55k ecu may be important. Also, have you had it hooked up to STAR to see what's going on? The Central Gateway may also need to be coded, but that's just a guess, and that requires online coding. Good luck and hope you get it sorted, you'll enjoy the extra power I'm sure.
