coolant system diagram
Old Mar 14, 2022 | 10:16 AM
msgbueno's Avatar
s55 amg
does anyone have the coolant system diagram available?
coolant is somehow leaking into the oil pain. cant find the leak. no coolant leaks outside - bone dry. block test is negative. also put coolant dye in the overflow reservoir and looked with a black light. no coolant leaks found. theres some oil leaks on the driver side valve cover gasket but thats about it. any help appreciated
2003 mercedes s55 amg
Old Mar 15, 2022 | 09:26 AM
ls1_mast's Avatar
w220 S55 AMG 2004
u might have an inyernal leak from the cylinder head gasket that ONLY happen when the car is hot , so metal expands and due to the fact that your cylinder head might be ( not flat ) u might need to flatten it
