2006 S55 transmission electrical plug
You must not be looking hard enough to find the cable that connects to the transmission. It’s un-missable.
At over 15y, if the fluid and filter have never been changed, be happy if you don’t need a new transmission.
GL
maw
EDIT... if these symptoms just started you MIGHT be OK with a basic service and plug.
Cheers,
maw
Cheers,
maw
Here again, the price is much less relevant than the 2 years of driving that have passed since you first asked the question. They're not raping you... get it done already.
I don't want you to cause $2,000 worth of work trying to save or postpone $200. That's where people go wrong with these cars, and the car is ruined thereafter.
maw
The transmission pan does not need to be dropped to change the 13-pin connector.
Here's a pic of where it's located. Remove the harness and use a 7mm socket to remove it.
You will need to remove a heat shield first. Once you do, you'll see it.
