ABC Fluid Leak, Help with any Ideas Pls.
Old Jun 7, 2023 | 08:34 PM
Shax Shux's Avatar
2003 S55 Kompressor
Hi all, so earlier I had a leak from the ABC tank cap, ABC light came on but I added fluid later on and light went away, meanwhile ABC works, raise/lower but car feel not steady while driving with no aerodynamic. Should I start straight from the pump replacement or what else?
Thanks!
Old Jun 17, 2023 | 01:37 PM
JohnLane's Avatar
222 S-65
Leak from ABC pump cap means a nitrogen bomb died and pushed hydraulic fluid out the reservoir. One end of the car will feel really harsh over bumps. Get it fixed NOW so it does not blow up hydraulic hoses.
Old Jun 18, 2023 | 10:04 AM
GrepAwk's Avatar
'03 S55 (79K miles)
Agree
That’s the first sign of a burst accumulator. Nitrogen rushes through the line and pops through the return port under the cap with enough force to push some fluid out. Then extra fluid rushes into the accumulator to fill the void and that leaves the level in the reservoir looking too low.
