S55 AMG License plate bulbs flickering/not turning on
Old Sep 6, 2023 | 02:05 PM
RLNY's Avatar
C55 AMG
So the left bulb flickers and the right does not come on. I put in new bulbs and tried electric cleaner and it doesn’t stay on for the left and right still doesn’t come on. Not sure what the problem is. Was thinking of trying to throughly clean the connectors with a tip.
Old Sep 6, 2023 | 08:48 PM
maw1124's Avatar
'06 MB S55 AMG; '04 Audi Allroad 4.2; '05 BMW M3 Conv.; '92 MB 500E
https://mbworld.org/forums/s-class-w...ng-repair.html
Let’s hope it’s not your rear SAM. Any other lights not working? You might try disconnecting the negative terminal for an hour. Reconnect on the :00 or :30 to help the COMAND clocks synchronize. That’ll reset electronics in the whole vehicle. You might also try LED bulbs which require less power.
Disclaimer: I’ve not had these problems but I know from experience with other bulbs the SAM can be the culprit. Let’s hope a simple reset is all it needs.
maw
Old Sep 6, 2023 | 09:29 PM
RLNY's Avatar
C55 AMG
maw
front side marker just went out yesterday. If it is the sam do I have to get a new one or reprogram this one. I will try what you said though
Old Sep 11, 2023 | 06:10 AM
ls1_mast's Avatar
w220 S55 AMG 2004
i believe what @maw1124 saying is that if you have any more lights that doing the same thing at the rear end or any weird stuff at the rear end too . because all of those lights at the rear end is controlled by the rear Sam. but front lights is controlled by the front Sam
Old Sep 28, 2023 | 02:18 PM
FL_S55AMG's Avatar
2004 S55 AMG
Do the above - also use dialectic grease...it does help
