S55 amg leaking coolant
This is not my photo I found it in another forum but im assuming this is what it is because he was leaking from the same location.
Once the car is stable (make sure you have enough coolant obviously) start it and look for the culprit. I don't advise getting under it while its running on jack stands but you can get a better idea where it's leaking from.
Coolant leaks have funny way of running down hoses and dripping away from their origin, so it's hard to say if you have a pinhole leak, cracked radiator or heat exchanger, leaking hose, leaking intercooler pump, water pump weep hole, etc.
Have a look here to understand the routing of the cooling system components and hoses. https://nemigaparts.com/cat_spares/e...74/66t/50/200/
Hope this is of some assistance to you.
Hope this is of some assistance to you.[/QUOTE
i just need to find out what that hose is called or a part number to it. Most of Mercedes heater hoses are discontinued on their website so I’m going to have to find it second hand.
More heater hoses https://www.fcpeuro.com/Mercedes~Ben...5&b=5&d=711&v=
