S63 AMG 4MATIC Coupe, S65 AMG Coupe (C217), Convert. (A217) 2014 -2021
RENNtech | HSM | Hand-Held Suspension Module | S-Class
Old Nov 21, 2016 | 12:26 PM
RENNtechHQ's Avatar
Former Vendor of MBWorld
Mercedes-AMG
The RENNtech Hand-Held Suspension Module (HSM) is designed to work with the W222 - S-Class Sedan and C217 - S-Class Coupé/Cabriolet, equipped with the Mercedes ABC Hydraulic Suspensions. The unit allows the user to have full control over all four corners of the vehicle’s suspension and adjust in 1mm increments.
The HSM comes pre-loaded with a RENNtech lowering setting. User can load their custom setting onto the HSM to set the vehicle to their preferred ride height.
The desired lowering setting will be loaded onto the vehicle via the ODB2 port in the footwell of the car. After plugging the HSM into the ODB2 port, the user can toggle a switch to load the factory or the adjusted ride height. After a few seconds, the new setting is uploaded and the car will adjust to the new height.
The factory setting will always be stored on the HSM and the user can set the vehicle back to the factory setting.
Once the settings are loaded, simply unplug and store for future use.
All RENNtech HSMs are adjustable via USB using either Windows or Android OS. The software allows the user to adjust the ride-height at each corner in 1mm increments independently. The software also has three locations where the user can store pre-configured suspension setups for quick changes.
• Pre-loaded with a RENNtech optimized setting
• Fully adjustable with the RENNtech Suspension Software
• Custom setting loaded onto suspension module via USB
• Lower and raise your car through the ODB2 port within seconds
• Full Installation time 10 seconds
RENNtech HSM Product Page
