S63 AMG 4MATIC Coupe, S65 AMG Coupe (C217), Convert. (A217) 2014 -2021
RENNtech hand held tuner ECU upgrade S63 Gains: +82 HP & +84 LB-FT
Old May 13, 2019 | 08:54 PM
BlackC230Coupe's Avatar
Former Vendor of MBWorld
Fast Cars!
Hello all,
Below is information on the C217 S63 RENNtech hand held tuner ECU upgrade. By far and away the most easy way to tune your ECU or change it back at anytime by far and away the ONLY company I would trust in ECU tuning for Mercedes.
Up to 773 HP / 778 LB-FT
These are available for immediate shipment once we receive your VIN . Please contact me for a shipping promotion we are offering at either info@etkms.com or call 1-866-950-7779
Orders can be placed via the website here https://www.euroteckracing.com/produ...er-ecu-upgradeor by phone.
RENNtech HHT (hand held tuner) allows you the unlimited ability to switch between tuned and stock ECU programming and requires no ECU removal!
Our proprietary tuning module stores both the RENNtech tuned file and your vehicles stock file. The module plugs directly into the OBD2 port and delivers the file you choose directly to the ECU. Programming takes only a few minutes and the vehicle can be reflashed at any time as many times as you wish.
RENNtech has been at the forefront of ECU tuning since electronic engine management started to show up in vehicles during the mid 1980s! Our experience, countless hours of in-house research, development and exhaustive testing ensure that our proprietary ECU upgrade offers incredible performance gains and rock solid daily driver reliability.
RENNtech tuning software for Mercedes offers significant gains in horsepower and torque across the vehicle's entire power band. By modifying ignition timing and throttle mapping, optimizing air-to-fuel ratios, increasing the engine's rev limiter and modifying boost mapping for turbo-charged vehicles, RENNtech performance software unleashes the true potential of your Mercedes.
With the proprietary RENNtech ECU Tuning the C217/W222 - S63 AMG 4MATIC+ gains up to +82 HP and +81LB-FT, based on power numbers measured by RENNtech. Please note that the Mercedes M177 engine performance when measured, obtains higher numbers than rated from factory. The maximum power number reached with the RENNtech ECU Upgrade for the E63 AMG S 4MATIC+ is 773 HP and 778 LB-FT.
Notes:
  • We have found the M177 engine stock performance numbers vary from the baseline figures claimed by Mercedes-Benz. We typically see higher baseline numbers than claimed by the factory.
  • Power gains are calculated based on stock numbers measured by RENNtech. Crank Performance Numbers are calculated with a 14% Drivetrain loss on 4MATIC+ vehicles.
  • Numbers published by MBUSA are an average over a 750rpm range for HP and a 2,000rpm range for TQ. Power gains are calculated based on the peak stock performance measured by RENNtech.
  • Our numbers will be dependent on conditions and fuel quality. 93+ Octane gasoline is mandatory with this Performance Upgrade.
S63 AMG 4MATIC+ (MY2018+ | W222 | M177 | 4.0L V8 BiTurbo) Modified Performance (at crank):
  • Rated by RENNtech (peak @crank): 773 HP @ 5,600rpm; 778 LB-FT @ 4,400rpm
  • Rated by RENNtech (peak @wheel): 665 whp @ 5,600rpm; 668 wtq @ 4,400rpm
    • Crank Performance Numbers are calculated with a 14% Drivetrain loss on 4MATIC+ vehicles.
