S63 AMG 4MATIC Coupe, S65 AMG Coupe (C217), Convert. (A217) 2014 -2021
Transmission Temperature Question (S63 C217)
Old Nov 29, 2020 | 08:04 AM
GMBALL's Avatar
S63 COUPE M157
On my 2015 S63 - When in "AMG" instrument cluster display mode, the icons for the transmission fluid and oil temp (next to each gauge) are blue at startup, then each turns white once temperature is reached. I'm just curious.....in winter when it is colder it takes about 45 minutes for the transmission gauge to turn white, the temperature gets quite quickly to around 40 degrees mark, but then about 30 minutes to 45 degrees and turns white. This then means it takes roughly an hour of normal driving to allow me to use it's full acceleration potential, which I find very "limiting".
So, do you guys also wait all the way until it goes white to use 100% power?
Or maybe does the car limit RPM or HP when these gauges are blue?
Thanks!
