Looking for info on Brembo Brake discs for S63 C217
I heard there are aftermarket brake discs made by Brembo that exactly fit our S63 c217 cars. And these are also quite a bit cheaper than the stock mercedes ones from the dealer. Does anyone here know the exact part number of these brake discs by any chance?
And help would be greatly appreciated, Thanks!
I added some pics of how they look.
They are 390x36mm
Brembo Part Number 09931333 (09.9313.33)
They used to be available at Rock Auto for $290!
They still have them, but they are now $400
I used them on my r231 SL550 AMG Brake conversion (see pic below)
They are 390x36mm
Yes, thats the part number I found now too. This also fits the c217 S63 AMG Coupe.
How were your experiences with driving these brake discs? And did you drive semi.metallic pads or carbon pads?
Pads are going to be a personal choice depending on how you’re going to use the car.
My wheels are easy to clean and it’s not a daily driver so I went with the Brembo low metallic compound. The compound works good for the street. Initial bite is excellent. They are OEM for several other brands Porsche, Audi, etc…. If you drive them super hard they WILL fade. But these massive rotors/brakes generate a lot of heat. I may try different pads at some point, but for my usage overall they work ok. I like Akebono pads but they don’t make a set for those Brembo/AMG calipers, Brembo has a ceramic compound I may try. I believe Ferrodo, Endless,TRW and several others make pads for these calipers so you have lots of choices. 👍
Cool, thaks for the info!
Manufacturer Part Number:
222 423 20 12 / 2224232012
Placement on Vehicle:
Driver or Passenger Side, Left, Right, Rear
Interchange Part Number:
A 222 423 20 12 / A 2224232012 / A222 423 20 12
Brake Disc Style:
Vented and Cross Drilled and Slotted
Other Part Number:
A2224232012
https://www.topeuromachine.com/produ...pr_seq=uniform
