S63 AMG 4MATIC Coupe, S65 AMG Coupe (C217), Convert. (A217) 2014 -2021
Canadian vehicle, switching C to F
Old Mar 22, 2022 | 08:24 AM
Amont226's Avatar
S63 AMG Designo
Hello all, recently we acquired a 2017 S63 AMG Coupe, Designo edition from Canada. The vehicle’s temperature readings are in Celsius and we’d like to change them to Fahrenheit. We’ve taken it to a reputable local Mercedes dealership with no luck. It’s our understanding that we aren’t the only ones to have experienced this. What’s a good permanent solution that some of you have found?
thank you for your time!!
Old Mar 22, 2022 | 11:15 AM
superswiss's Avatar
2019 C63CS
There is no solution that I've come across. I'd actually like to do the opposite as I grew up with Celsius. The unit of measurement for temperature is the prevailing unit in the region the car is coded for and can no longer be changed. The car's region has to be changed, which is something only the factory and the VPC can do as far as I know. I've contacted MBUSA about this a while back, inquiring why there isn't a user controllable setting for this. On my previous Audis I could change all the units of measurement, including temperatures, to what I wanted, but with MB one can only change the distance unit of measurement. Pressure and temperature are region specific.
Old Mar 22, 2022 | 08:12 PM
First_Username_'s Avatar
2014 gl 63
You should try reaching out to Vlad. He knows how to get in and reprogram factory settings.
canfiltermb@gmail.com
Old Mar 23, 2022 | 07:08 PM
amir1's Avatar
2019 S65 Coupe, 2017 S650 Maybach Convertible, 2020 S560 Sedan, 2022 Porsche 911 Turbo S
That's disappointing. I could have sworn I was able to change it in settings. Maybe it was my older 2017 S550 that I could. Bummer.
