S63 AMG 4MATIC Coupe, S65 AMG Coupe (C217), Convert. (A217) 2014 -2021
s63 coupe door gasket
Old Aug 4, 2023 | 12:33 PM
PoLo_Jose's Avatar
2015 s63 coupe 2018 s450 ,2016 X6
I have. a 2015 s63 coupe 31k miles and for what ever reason the inside door gasket is white , looks like it is worn don’t know y , it was a florida car before i got it … does anyone know how much it would cost to replace it ? .. so far most body shops don’t even want to touch it they said labor is to much .. thanks
Old Aug 6, 2023 | 04:56 PM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
rubber truns white. porsche and MB use krylox lube to rub on them, it is expensive. i found a simular lube called ultimox 226 for 25-30$ and have used it for several years. my window rubber was turning white, I rubber it with ultimoz and it looks new again.
Use very little, rub it in hard. It will stay greasy for a while, dont get it on the paint or leather
Old Aug 6, 2023 | 06:50 PM
PoLo_Jose's Avatar
krylox lube
i ordered the ultimox 226 i would also order the kylrylox to see what works better . the rubber is already white and feels ruff in some spots , will it turn the white parts back black ? .. also was going to put it on the soon roof gaskets … any idea on how much it would cost to replace ?
Old Aug 6, 2023 | 08:36 PM
okbarnett's Avatar
it should turn them black. I have used it on 3 or 4 cars and it works. You can put it on any gaskets and it should work But use very little on a rag, and wipe it in. Let it sit for a coupe days and if it needs more, do more coats
