S63 AMG 4MATIC Coupe, S65 AMG Coupe (C217), Convert. (A217) 2014 -2021
New to me S65 coupe! 🔥
Old Nov 17, 2024 | 09:54 PM
richvegas's Avatar
2016 S65 AMG coupe, 2010 E63, 2015 Z06/z07 m7 vert 735rwhp, 2000 f-350 crewcab w/ 16" kelderman kit
Beautiful car! Some nice fresh HRE's would look amazing on that car!
I do accept donations 😎🤣
honestly haven’t seen an aftermarket wheel on these I really like. I’m down for suggestions 🤙🏻
Old Nov 18, 2024 | 06:50 AM
hyperion667's Avatar
2012 CLS63
LOL, donations, that's funny.
But honestly, my choice would be different from yours, and after having many sets of HRE's and colors too, I'd probably go with one of these.
I'm current rotating between the 301M and another set
P101
312 GTS
301 M
Old Nov 19, 2024 | 07:30 AM
robke011's Avatar
Brabus S Coupe, Brabus Smart Ultimate E, Brabus GLB 35
I've changed 3 sets of wheels on mine until i found ones that i like, highly recommend
Old Nov 19, 2024 | 06:24 PM
richvegas's Avatar
These look like the wheels AutoVlog has on his car (Youtuber)
Old Nov 19, 2024 | 07:34 PM
richvegas's Avatar
Finally!!
Backing plates , fluid , and plugs. Two YouTube videos to come!
Old Nov 20, 2024 | 09:53 AM
xabo's Avatar
'20 S63
Very similar.......he's running Axe wheels
:https://axewheels.com/axe-wheels-ex2...yPwiugpsaszOWJ
Old Nov 20, 2024 | 11:59 AM
  #32
richvegas's Avatar
I tried to buy that car too but he was unrealistic in pricing.
Old Nov 21, 2024 | 04:32 PM
  #33
ChinbakwaAss's Avatar
Mileage
How many miles did it have when you purchased
Old Nov 21, 2024 | 04:39 PM
  #34
richvegas's Avatar
my car had 19k miles when I bought it in late September
Old Nov 21, 2024 | 06:37 PM
  #35
carlosinseattle's Avatar
Top Answer: 1
2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
Finally!!
When I first saw your post I wondered if you were changing plugs in a fleet of cars, then realized...2 plugs per cylinder for your V12 means 24 spark plugs...WOW!!!!
Old Nov 28, 2024 | 02:27 AM
  #36
richvegas's Avatar
Old Nov 28, 2024 | 05:54 PM
  #37
richvegas's Avatar
Old Nov 28, 2024 | 06:36 PM
  #38
W205C43PFL's Avatar
https://cimg3.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/img_0890_ce63517dd3a5fa1a383e1616e98aba95cc1f0b81. jpeg
https://cimg4.ibsrv.net/gimg/www.mbw...36d24f5b7.jpeg
https://cimg6.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/img_0908_cd651f59bf50d7ccb67d3859af176364f445bce1. jpeg
Oh boy! CCBs
Old Dec 1, 2024 | 09:53 AM
  #39
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
Wow! great job
Old Dec 5, 2024 | 02:15 PM
  #40
Jim Ma's Avatar
S 550, S65 Coupe
How was the install? Pretty straight forward? Swap the rotors and calipers, new dust shields and use the existing or new hoses? Then just bleed them and all good to go?
Also do you feel the investment was worth it? I love the idea of CCB but have no real complaint about the stock set up. Already swapped pads so dust is no longer a problem.
Old Dec 10, 2024 | 04:21 PM
  #41
richvegas's Avatar
The install was pretty straight forward. The backing plates actually were not needed, they are no bigger than the original ones and required different hardware. The calipers came w the hoses still attached and they screwed right into the metal lines. Bleed procedure was done with a vacuum tool and was easy/normal.
Some take aways:
-The rear calipers are the exact same as the other ones just painted a different color. Brackets same too.
-Rear rotors are Carbon but they are the same size as the original
-Front rotors are about 1-1.5" larger in diameter
-Front calipers are larger and look so goooooood!
-Found front brake sensor harness (not the sensor) is not the same. Had to order from Germany again...
-Brakes feel much stronger when leaning into them harder.
-Pedel is a little stiffer than before but feels good.
-THEY LOOK AMAZING!!!! AND 100% WORTH IT!!
Old Dec 10, 2024 | 05:07 PM
  #42
W205C43PFL's Avatar
Some take aways:
Old Dec 10, 2024 | 09:47 PM
  #43
FDNewbie's Avatar
'17 AMG S63 Convertible, '17 AMG C63S Edition 1 Coupe
Some take aways:
So you're saying the front rotors are carbon ceramic, and have a different caliper, and the rears are steel rotors with the same caliper, but painted gold, right?
If so, the ironic part is, that's the exact same with the W205 C63. Ceramics up front, and steels with gold caliper in the rear.
The E63, however, has carbon ceramics all around. So an upgrade on the W205 C63 that already has ceramics (fronts only) is to upgrade the rears to the E63 rear carbon rotors & calipers.
Wonder if those would also fit the S63...esp since manufacturers typically develop one product and make it fit multiple applications/models...
Old Dec 10, 2024 | 10:01 PM
  #44
richvegas's Avatar
The rear rotors are 100% carbon fiber. The rear pads are the same size and a different part number the rear calipers appear to be exactly the same but a different color.
Old Dec 10, 2024 | 10:13 PM
  #45
FDNewbie's Avatar
Ah you were referring to the pads and calipers. Gotcha. That makes more sense. Cuz a heavy car like the S63/S65 would def benefit from CCBs on all 4 corners..
