S63 AMG 4MATIC Coupe, S65 AMG Coupe (C217), Convert. (A217) 2014 -2021
Cam sensor oil leak in wiring harness/ prevent new ECU and engine wiring harness
Old Nov 6, 2024 | 03:08 PM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
Cam sensor oil leak in wiring harness/ prevent new ECU and engine wiring harness replacement ($15,000) I checked all 8 of the sensors, all are dry. I am buying the MB magnet pigtails,eBay item number:175787432702,
and the ZZ Performance position sensor pigtails on ebay, eBay item number:115699950640
You also need to check the vacuum solenoid on top of the engine, the vac in tube for oil in the tube. If it has oil you have to replace the solenoid
Old Dec 23, 2024 | 02:41 PM
2014CL600's Avatar
Cars
What are you showing us?
That isn’t your cam sensor or where the sensor leaks from.
Old Dec 23, 2024 | 07:34 PM
okbarnett's Avatar
