S63 brakes
FCP Euro has the front Brembo rotors for $603 ea These are coated. They don't rust as bad as MB stock. And they are as high quality. These ard $1600 ea from MB and most dealers
Ebay has Brembo rears, same rotor, for $682 ea. Seller is Parts Container. These are more than the fronts, $1800 ea from MB and most dealers.
I got this set and have my EBC red pads. Really a good setup. Very very little dust.
The rears wear more than the fronts. I think they have alot of bias on the rears. You can see the Brembo UV coating burns off the pad wear area after about 10 miles. The coating prevents alot of rust and if you keep the rotor washed and use wheel cleaner it really stays clean a long time. I have brembo rotors on another car for 5 or 6 years, I dont spend time on it, and they are still pretty clean.
