Vivid Racing ◄♦► Meisterschaft Exhaust
The Meisterschaft brand is for enthusiast that demand only the highest in quality, sound & performance,
choices, and ultimate satisfaction. Their quality and craftsmanship is second to none.
Vivid Racing is proud to be a distributor for all Meisterschaft exhaust products.
1. Weight - The Meisterschaft GTS and GTC system is significantly lighter than the OEM unit to reduce unsprung weight. With the Meisterschaft Ti Titanium units, it is 70% of the weight of the OEM unit.
2. Performance - All Meisterschaft systems are designed and tuned to provide maximum performance gain without sacrificing the exotic exhaust note. The perfomance gain will be even greater when the Cat-back pipes are used in conjunction with the Meisterschaft muffler.
3. Build Quality - Welding technique and internal construction are handled with extreme care and also given more attention to details compared to other brands.
4. Material - Only the highest grade T304 SUS from POSCO is used for Meisterschaft SUS units.
5. Control - The GTC system has electronically controlled variable chambers that open and close depending on the engine's performance as well as your choice, with the optional wireless remote control. High revving makes the valves open for a louder, more aggressive sound and even better performance, and closes for normal cruising for a comfortable sound but still louder than stock. Almost sleeper in nature, nobody would suspect the car has a beast ready to roar inside. The GTS system has no control valves but it's sound and performance is right in the middle of the GTC. You get a louder, deeper sound and the added performance. It's right in the middle for the best all around gains. Add the resonator delete mid-pipe for even bigger gains!
S63 (V8 Bi turbo) AMG Coupe (2015+) GTC $4998 MSRP
S65 (V12 Bi turbo) AMG Coupe (2015+) GTC $4998 MSRP
S550 (V8 Bi turbo) Coupe (2015+) GTC $4998 MSRP
GTC Wireless Remote Control $150 MSRP
S63 (V8 Bi turbo) AMG Coupe (2015+) GTS $4498 MSRP
S65 (V12 Bi turbo) AMG Coupe (2015+) GTS $4498 MSRP
S550 (V8 Bi turbo) Coupe (2015+) GTS $4498 MSRP
Resonator delete mid-pipe for cat-back system $1998 MSRP
We only show you MSRP so you know how much you'll save with our great deals!
Find out what we can do for you.
Jacky - 480.966.3040 x2229 - jacky@vividracing.com
