S63 AMG, S63 AMG 4Matic, S65 AMG (W222, V222) 2014 -2021
2008 s63 engine noise please help
Old Aug 22, 2017 | 04:11 PM
Sfcprez415's Avatar
S63 amg
My s63 been in the shop for 2 month now. It started making noise only when it's fully warmed. The noise goes away when you step on the gas. So far I changed Idler pulley three of them belt tensioner belt. Harmonic balancer. Water pump and Alternator and it's still making the noise. Anyone have the same problem? https://youtu.be/623dOJwp3Lo
Old Aug 22, 2017 | 09:58 PM
barryrobinson19's Avatar
2016 Mercedes S63 4matic sedan
Have you tried spraying some silicone spray on the main drive belt to see if the noise go's away or changes?
Just something to try.
Old Aug 22, 2017 | 10:26 PM
Sfcprez415's Avatar
S63 amg
I replaced all the belts but I will give it a try thanks for the tip
Old Sep 4, 2017 | 09:49 PM
johnksss's Avatar
2011 S550 / 2001 S430 - RIP
Speculations..... The A/C compressor bearing might be going out.
I only say this because I went through it on my 01.
Old Sep 4, 2017 | 11:03 PM
Sfcprez415's Avatar
S63 amg
I just ran the car without the v and it's was making that noise. Only when the car is super hot so it has nothing to do with a/c compressor.
Old Sep 5, 2017 | 11:20 AM
johnksss's Avatar
The "V"? Is this the same as you removing the serpentine belt and running the engine?
What about the fan?
I sure hope mine does not have this problem when it comes time for me to purchase it...
Old Jan 5, 2023 | 07:45 AM
MannyEuro's Avatar
mercedes
Yes when making the noise try to remove the oil cap to find out if it has a lot of vacuum holding the cap down. If it does the problem might be because of a bad crankcase vent valve.
