S63 AMG, S63 AMG 4Matic, S65 AMG (W222, V222) 2014 -2021
Tranny and Oil Temps??
Old Dec 14, 2018 | 09:36 AM
Busa196's Avatar
2018 S63, lowered
Question Tranny and Oil Temps??
Just curious for those of you that keep your display in the AMG mode, what are you seeing for oil and tranny temps?
Old Dec 16, 2018 | 12:37 PM
barryrobinson19's Avatar
2016 Mercedes S63 4matic sedan
Outside temperature around 54 degrees, 80mph highway cruising, engine oil around 200 degrees, transmission around 190 degrees. hope this helps.
Old Dec 18, 2018 | 09:24 PM
Busa196's Avatar
2018 S63, lowered
Thanks for that Barry. I see close to the same +/-10 degrees in 50-80F. My oil temp is usually about 210-220. The reason I ask is my 08 Z06 normally runs 180-190 in the heat of summer in Houston in normal driving. To get it to go over 200 I have to beat on it 2-3-4 times in 100 degree ambient air. I’ve only owned the 63 for about 6 weeks and me seeing 210-220 under normal driving is not what I’m used to- but my Tech at the dealership who’s awesome and been an AMG tech since I was attending prom assured me that’s totally normal.
👍👍 Thanks again!
