AutoTalent | Renntech Ecu + Exhaust + Suspension For Mercedes-benz S 65 AMG Biturbo
Golan@AutoTalent.com
Renntech Performance Ecu Upgrade
Click HERE to order Performance Ecu!
RennTech HHT (hand held tuner) allows you the unlimited ability to switch between tuned and stock ECU programming and requires no ECU removal. RennTech proprietary tuning module stores both the RennTech tuned file and your vehicles stock file. The module plugs directly into the OBD2 port and delivers the file you choose directly to the ECU. Programming takes only a few minutes and the vehicle can be reflashed at any time as many times as you wish. RennTech has been at the forefront of ECU tuning since electronic engine management started to show up in vehicles during the mid 1980's. RennTech experience, countless hours of in house research, development and exhaustive testing ensure that our proprietary ECU upgrade offers incredible performance gains and rock solid daily driver reliability.
Features
Long-lasting and driver reliability
Significant gains in horsepower
Increases the performance
Significant gains torque
Increasing the engine's rev limiter
Incredible performance gains
Stock Performance:
621 HP @ 5500 RPM; 738 LB-FT @ 2000-3000 RPM
Modified Performance:
670 HP @ 5500 RPM; 840 LB-FT @ 3500 RPM
Renntech Hand-held Suspension Module
Click HERE to order Hand-held Suspension Module!
The RennTech Hand-Held Suspension Module (HSM) is designed to work with the W222 - S-Class Sedan, equipped with the Mercedes Airmatic and Magic Body Control Suspensions.The unit allows the user to have full control over all four corners of the vehicle’s suspension and adjust in 1mm increments. The HSM comes pre-loaded with a RennTech lowering setting. User can load their custom setting onto the HSM to set the vehicle to their preffered ride height. The desired lowering setting will be loaded onto the vehicle via the ODB2 port in the footwell of the car. After plugging the HSM into the ODB2 port, the user can toggle a switch to load the factory or the adjusted ride height. After a few seconds, the new setting is uploaded and the car will adjust to the new height. The factory setting will always be stored on the HSM and the user can set the vehicle back to the factory setting. Once the settings are loaded, simply unplug and store for future use. With the newest update to HSM, the user is now able to adjust the suspension settings directly in the on-board command system in their Mercedes. After plugging the HSM into the OBD2 port, the RennTech HSM Screen will appear on the Mercedes Command screen. After changing and saving the settings, the module can be unplugged and the screen goes back to the regular Mercedes menu. No tools, laptop or tablet needed. Full Plug'n'Play Solution. All RennTech HSMs are adjustable via USB using either Windows or Android OS.The software allows the user to adjust the ride-height at each corner in 1mm increments independently. The software also has three locations where the user can store pre-configured suspension setups for quick changes.
Features:
Allows the user to have full control over all four corners of the vehicle’s
Adjustment increments: 1mm
Maximum Lowering: Limited only by vehicle
Adjustment Methods: PC or Android (Tablet)
Size: 73mm x 44mm x 24mm
Renntech Aero Carbon Fiber Decklid Spoiler
Click HERE to order Decklid Spoiler!
RennTech is proud to introduce an all new rear decklid spoiler design for the Mercedes-Benz S-Class. This highly integrated pre-preg carbon fiber spoiler compliments the sophisticated and refined S-Class exterior design language. The spoiler is coated inside and out with an all new acrylic UV protection system. A second layer of UV protectant clear coating is also applied using traditional spray methods. The rear spoiler integrates seamlessly into the rear of the vehicle and offers a dramatic, unique appearance to the rear exterior. RennTech is proud to introduce this sporty yet elegant rear deck lid spoiler for the S-Class. The rear spoiler integrates seamlessly into the rear of the S and offers a dramatic, unique appearance to the rear exterior. RennTechfull carbon fiber spoiler is manufactured from extremely high quality, prepreg carbon fiber and available in both matte or gloss finish.
Features
Stunning good looks of vehicles
High quality meterials used
Looking more aggressive
Carbon Fiber meterials
Design is perfect
Simple to install
Renntech Exhaust Stainless Steel Sport Muffler
Click HERE to order Stainless Steel Sport Muffler!
RennTech stainless steel (SS) sport mufflers are hand made and rigorously tested to remove any unwanted resonances in the cabin to deliver a deep sound that keeps with the character of a luxury performance vehicle. RennTech Sport Mufflers are made out of T-304 stainless steel (SS) and 100% hand crafted in the USA. This exhaust system is rigorously tested to remove any unwanted resonances in the cabin to deliver a deep sound that keeps with the character of a luxury performance vehicle. RennTech mufflers with 2 3/4 inch diameter tubing offer lighter weight than the stock exhaust and improve performance by reducing exhaust back pressure, increasing exhaust gas flow and cylinder scavenging.
Features
Improve performance by reducing exhaust back pressure
Lighter weight than the stock exhaust
Stainless steel (SS) sport mufflers
Improving exhaust gas flow
Gains up to up to 10 HP & 15 TQ
Renntech Performance Transmission Upgrade
Click HERE to order Performance Transmission Upgrade!
Click HERE to order Performance Transmission Softwares Upgrade!
RennTech transmission upgrade consists of a complete transmission disassembly and inspection as well as a mechanical upgrade to the transmission clutch packs. This allows us the ability to maximize the amount of friction materials contained within the transmission and in turn, the amount of power which can be transmitted through each forward gear. During final assembly the transmission also receives all new gaskets, seals, o-rings as well as a new transmission pan filter. RennTech Mercedes Transmissions increased engine performance it becomes necessary to further improve the drive line components, most importantly the transmission in order to ensure maximum power is transmitted to the drive wheels without transmission slippage. This can not be realized with software and only truly be accomplished by an internal mechanical upgrade to the transmission hardware. RennTech is the foremost authority on transmission upgrades and has done countless rebuild and upgrades for the most demanding dealers and clients for over 21 years. RennTech upgrade leads to improved shift response, shift timing, increased torque handling capabilities and greater drivability under extreme conditions without sacrificing around town comfort.
Features
Ability to maximize the amount of friction materials
Increased torque handling capabilities
Improves vehicles responsiveness
Increased engine performance
High quality material used
Improved shift response
Improved performance
Greater drivability
Shift timing
Renntech Performance Carbon Fiber Airbox
Click HERE to order Renntech Performance Carbon Fiber Airbox!
RennTech optimizing the path and increasing the volume of incoming airflow, RennTech carbon air box is able to offer gains up to +10 hp and + 10 lb/ft, in addition to serving as an attractive under hood showpiece. RennTech kit comes complete with high flow performance filter inserts and anodized aluminum MAF sensor retaining clips. Using the highest quality pre-preg carbon fiber, our 4-piece airbox kit for the 63 series biturbo M157 engine comes complete with flow optimized turbo tubes to maximize engine performance by increasing the volume of incoming airflow. The carbon fiber airbox was designed, engineered and manufactured in the USA using only industry leading materials to ensure long lasting durability and appearance. The Carbon Fiber Air Box kit includes a Set of 2 BMC high performance air filter. RennTech electronic engine management started to show up in vehicles during the mid 1980's. RennTech experience, countless hours of in house research, development and exhaustive testing ensure that RennTech proprietary air box offers incredible performance gains and rock solid daily driver reliability.
Features
Increasing the volume of incoming airflow
High flow performance filter inserts
Gains up to +10 hp and + 10 lb/ft
Carbon fiber material used
Renntech Carbon Fiber Airbox
Renntech Turbo Charger
How to Place Your Order:
Phone Domestic: (855) 973-2757 X 104
Phone International: (310) 231-7800 X 104
E-mail: online@autotalent.com
Website: www.AutoTalent.com
Payment:
Attachment 439933
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
