S63 AMG, S63 AMG 4Matic, S65 AMG (W222, V222) 2014 -2021
DIY Advice Request for B-stlye Rear Diffuser w F1 Light
Old Nov 28, 2020 | 01:06 PM
Tom Gallaher's Avatar
2018 AMG S63 W222
I just bought a Brabus style rear diffuser with F1 style light for my 2018 AMG S63 without install instructions. Does anyone have these or at a minimum can someone help me know where to best tie in the F1 brake light wires? Quick help would be greatly appreciated!
Old Nov 28, 2020 | 01:13 PM
phatisfy's Avatar
S-class
Run the wire to the brake light.
Old Nov 28, 2020 | 04:17 PM
2018 AMG S63 W222
Thank you. So this won't generate fault codes?
Old Nov 28, 2020 | 05:42 PM
phatisfy's Avatar
S-class
I don’t think it should? Just tap into the brake light wire since the bumper is already off to see if it’ll give you any codes? If you can find a wire diagram from a euro spec for the s63. It should tell you exactly how the wires are ran. Because the euro spec version also have the lower light.
Old Dec 15, 2020 | 03:04 PM
sambam2006's Avatar
GLC Coupe, S63L W222
Out of curiosity where did you end up wiring your F1 light? My Brabus diffuser is arriving soon so thought I rather be prepared.
Old Jun 22, 2023 | 11:17 AM
alexdou111's Avatar
DESIGNO CLS 63 AMG 2012
I had the same question today ended up testing, i connected to the same fog Light connection the stock fog Light Was connected to.
In my case it was grey to Red and Black to brown. The yellow did not connect to anything.
Old Jun 22, 2023 | 08:00 PM
phatisfy's Avatar
S-class
Did you connect it so that the light will light up as a brake light when you step on the brake pedal? Or it’s just stays on?
