S63 AMG, S63 AMG 4Matic, S65 AMG (W222, V222) 2014 -2021
OBD Lowering Module
Old Aug 29, 2021 | 12:35 PM
sumanchaudhuri's Avatar
Mercedes S55 AMG
OBD Lowering Module
For those of you that use the Amazon OBD lowering module, do you just leave it plugged in all the time into the OBD port so that you can lower it when parked, and raise it when driving? Or do you have to pull it out and plug it back in every time for the settings to show up on your dash?
Old Aug 29, 2021 | 11:10 PM
1SickGLC's Avatar
2018 MB GLC 43 AMG
Set it, remove, and enjoy the drive. If you want to switch it back and forth, you can always plug it back in to do so.
Old Apr 13, 2022 | 06:16 AM
Steve099's Avatar
S350 Edition S AMG Line
can these modules be used to increase the max height the vehicle will raise, when using the raise function?
