S63 AMG, S63 AMG 4Matic, S65 AMG (W222, V222) 2014 -2021
//// Help //// Has anyone bought or has done the AMG S63 Face lift with TRUE PLUG & P
Old Feb 23, 2023 | 06:41 PM
bimmerm3's Avatar
2004 E55
If so which kit or who did you purchase from that was truly plug and play
lights . I do not want to program lights to car.
Old Feb 23, 2023 | 08:13 PM
carlosinseattle's Avatar
Top Answer: 1
2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
You might want to check on the W222 area. Most of the people here already have AMG vehicles and wouldn't have any need for this upgrade kit. Maybe if they have a pre facelift S63, but I think this listing is for non AMG W222's.
Old Feb 26, 2023 | 12:56 PM
sambam2006's Avatar
GLC Coupe, S63L W222
I know 2 people who have had it done and they have issues with adaptive beam assist because of the front headlights and also the night vision assist plus stops working, function is cancelled.
I have a S63L W222 2016 and was looking to do it but just fishing for more information as well.
(Based in UK)
Old Feb 27, 2023 | 08:39 AM
stever500's Avatar
2025 S63. 2022 911 Turbo S, 23 BMW M5C
I would think it would be better just to buy the newer car with all this stuff on it if it's in your means, and if not, let well enough alone.
Old Feb 28, 2023 | 07:39 AM
phatisfy's Avatar
S-class
(Based in UK)
I’ve done it and everything works as supposed to. I also have the night vision option for the headlamps. So as long as you get the correct parts then you should be fine. I ordered my headlamps and the required module to code the headlamps (w/night vision) from the company in the link I included below. So if you have the night vision option. Then you must confirm with that to the company when purchasing. The module will only work with OEM or Magnet Marelli brand head lamp. Aftermarket will NOT work.
https://shop.awawdeh.ae
https://shop.awawdeh.ae/part-W222ADA...-class-adapter
Once the correct headlamps and module are sourced. You then have to contact Carsystems so that they can code everything. They will do this remotely by connecting to your laptop.
https://carsystems.com.ua
