S63 AMG, S63 AMG 4Matic, S65 AMG (W222, V222) 2014 -2021
Checking engine Oil Level
Old Oct 14, 2024 | 07:04 PM
xabo's Avatar
'20 S63
When checking the engine oil level via the onboard computer, the manual states:
Checking the engine oil level using the on board computer Requirements: The engine has warmed up. The vehicle is parked on a level surface. The engine is running at idle speed.
This goes against everything I have learned.
Old Oct 14, 2024 | 07:23 PM
superswiss's Avatar
2019 C63CS
Against everything you learned? Did you learn how to measure oil level on the basis of the capacitance of the engine oil? The oil has to flow through the condensers. Ain't no dipstick or float switch. The capacitance of the entire volume of oil changes based on the fill level. The oil doesn't have to collect in the oil pan to measure the fill level as is required with the traditional dipstick approach.
I'm not an expert in this stuff, but below is some info I found. There are different types of sensors that can be used to measure oil level. BTW, as you can see it doesn't just measure oil level, but also oil quality as in how much the oil is contaminated.
Old Oct 14, 2024 | 07:28 PM
xabo's Avatar
'20 S63
Yes, I was taught that you check the oil level with the engine off. This was even with my 2008 CL65. never too old to learn something new.
