S63 AMG, S63 AMG 4Matic, S65 AMG (W222, V222) 2014 -2021
Tried searching, quick question regarding oil wicking up harness.
Old Nov 28, 2024 | 02:34 PM
carranza913's Avatar
2013 e350, 2016 S63
New to me M157 2016 s63. Going through and completing all the regular maintenance. All of the cam solenoids were leaking. I cleaned the harness side and replaced with new solenoids. I’ll do the magnets next, I installed the pigtails on the magnets for the time being. Do I need to do anything else to prevent oil wicking? I checked the ecu side and no oil at that end. Just want to prevent.
Old Nov 28, 2024 | 02:38 PM
W205C43PFL's Avatar
As long as you cover everything in this video, you should be fine also check the description of the video:
Old Nov 28, 2024 | 02:49 PM
2013 e350, 2016 S63
Yes I did that, I had oil on the plugs on the harness side. I cleaned them very well but want to make sure oil will not still work up the harness.
Old Nov 29, 2024 | 03:49 AM
jcarsnz's Avatar
The oil pump solenoid is also known to leak into the wiring harness. I assume you know the other benefits to disconnecting this part, if not here is some light reading:
https://mbworld.org/forums/w212-amg/...solenoids.html
Old Nov 29, 2024 | 09:14 AM
W205C43PFL's Avatar
I see, sorry I missed your post. That videos cover most of them.
I agree with the oil pump solenoid part as well.
Old Dec 3, 2024 | 08:55 PM
2013 e350, 2016 S63
[QUOTE=W205C43PFL;9072232]I see, sorry I missed your post. That videos cover most of them.
I agree with the oil pump solenoid part as well.[/QUOTE
this part throws a cel when doing it on s63. I’m going to talk with benzninja about options
Old Dec 4, 2024 | 09:24 AM
W205C43PFL's Avatar
[QUOTE=carranza913;9074858]
To solve it, you could install a dummy solenoid outside of the oil pan.
