Injectors 1-4 Not actuating on water/flood cl63 amg 2012 59k mile auction purchase
I apologize if this is wrong forum but it's a general question and I'm desperate.
1
[img alt="whjresqs Avatar"]data:image/svg+xml;utf8,<svg xmlns='http://www.w3.org/2000/svg' viewBox='0 0 50 50'><circle class='avatar-circle-default' fill='%2359bbd0' cx='25px' cy='25px' r='23px'></circle><text class='avatar-text-default' x='49%' y='53%' fill='white' text-anchor='middle' alignment-baseline='middle'>w</text></svg>[/img]
whjresq
Hi,
I have a 2012 Cl63 Amg 59k miles bought at auction with flood damage title and injectors on passenger side not actuating in Xentry test with a new ECU. New plugs wires and coils and 02 sensor. 4 Plugs on one side were fouled black as was o2sensir. I changed ECU Still no actuating of those injectors and slow acceleration. I cannot locate area of water or flood intrusion. Really at a loss. I'm getting misfire crankshaft errors p something. Any ideas? Someone removed the injector soundproofing or padding insulation and high pressure fuel pump insulation. The Sam's have been checked and I replaced the fuel pump relay in both front and rear sam just in case. Any help would be aporeciated. Maybe unrelated but the sound amp was missing
Last edited by whjresq; Nov 6, 2025 at 02:36 PM. Reason: Omitted auxiliary battery warning
