Total Shutdown
Too bad if you are overtaking on the wrong side of the road.
Too bad that when the engine shuts down you loose the power steering.
Too bad that you loose the power Braking system.
At least the engine is protected against a potential warranty claim.
Too bad that the driver is at risk.
Under acceleration the engine management light came up closely followed by every warning light, the Total shutdown.
The dealer could not find a fault even though a fault code showed on the diagnostics
The same fault occured about a week later
The Dealer said it was a faulty injector and relaced the injector.
3 days later, the same fault occured.
The dealer said it was an air leak on the pipework and said they had fixed it.
The next day the same fault occured.
The dealer said it was a faulty fuel filter and they was some sort of knowledge of this particular problem.
I don't know for sure if that did cure the problem as I changed the ML for a Porsche Cayenne.
Compared to the latest 164 model ML there is not a lot to choose between the Porsche and the Mercedes. The Navigation is far superior in the Porsche,and the residual value of the Porsche will be greater as MB are already discounting the new ML quite heavily.Porsche allways sell at list prices.
So far the Cayenne has been faultless, and I am really pleased to have made the change.I also changed my SL 55 for a 911 Turbo S Cabriolet which is a lot quicker and handles well but the ride can be a bit bumpy !
