3WD|BRABUS AMG GT63S
SPONSOR
BRABUS 800
WORLD PREMIERE AT TOP MARQUES MONCACO29.05.19 - 588 kW eight hundred horsepower, a peak torque of 1,000 Nm (737 lb-ft), 2.9 seconds from rest to 100 km/h (62 mph). The top speed is electronically limited to 315 km/h (196 mph). Striking looks thanks to naked-carbon aerodynamic-enhancement components with sporty styling and hi-tech forged wheels in the new "BRABUS Monoblock Z "PLATINUM EDITION" with 21 and 22 inch diameters. The BRABUS 800 based on the new Mercedes-AMG GT 63 S 4MATIC+ celebrates its world premiere at the Top Marques Monaco 2019.
The four-liter twin-turbo V8 engine of the GT 63 S is uprated by the BRABUS powertrain engineers with the sophisticated BRABUS PowerXtra B40S-800 performance upgrade. The modifications to the engine hardware involve the turbocharging system: Two newly designed BRABUS high-performance turbochargers with larger compressor unit and modified core assembly with reinforced axial bearing produce a maximum boost pressure of 1.6 bar.
This results in an output increase by 118 kW / 161 hp (158 bhp) and a bump in torque by 100 Nm (74 lb-ft). With a new output of 588 kW / 800 hp (789 bhp) at 6,600 rpm and a peak torque of 1,000 Nm (737 lb-ft) at a low 3,600 rpm, the four-door coupe is one of the most powerful of its kind.
BRABUS garnishes the unique high-performance experience with an acoustic treat. The stainless sport exhaust, which is available for all GT 63 variants and optimizes the power delivery by reducing the exhaust backpressure, offers a variable exhaust note thanks to its integrated actively controlled exhaust flaps. The V8 can be operated in the decidedly subtle "Coming Home" mode or in the "Sport" position, which coaxes an extra powerful V8 sound from the engine. Thanks to its titanium/carbon tailpipes with a diameter of 90 millimeters (3.5 in), the BRABUS exhaust system is also an absolute visual delight.
FOR MORE DETAILS...CLICK THIS LINK..........THANK YOU!!!!
